Hello, Has anyone replaced the outer hub on their AC pump without removing it entirely? I know it was possible with the MK2 RS but space is more of a premium in the MK3s. I saw a member mention that the system is "clutchless" and spins indefinitely. If you see the centre spindle not spinning then the outer hub needs replacing. TIA
