MK3 Fender rubbing - solutions?
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by James M, Aug 22, 2023.
  1. Afternoon guys,
    Grabbed some new wheels in 8.5 et45 fitment and whilst they look great, they do rub a small amount on the rear arches. I picked up a fender rolling kit with the intent to get a bit more clearance only to realise that the rear 'over fenders' are plastic and can't be rolled.
    FYI - Current setup is mostly standard besides cooksport lowering springs
    Has anyone else had clearance issues they've solved before? Can you grind some of the plastic off with an angle grinder? Cheers guys appreciate your insight
  2. Get some cambershims for the rear maybe?
  3. How did you go with this? Currently dealing with the same issue.
    att.eJUBYj-D40iB3c_Hy_ej3yWBDf4BqeuVIZOVsCYHRpc.jpeg att.1ugI8im-ahWGU4OSmrF5FYbrnD9uxOxuLOaCzvQngCg.jpeg IMG_2624.jpeg
  4. Lifted it 10mm and the rubbing is barely noticeable unless it’s a big hit
    will still look to shim the rear for peace of mind
