MK2 lower hub inserts
Discussion in 'Car Parts For Sale' started by matt e, Sep 10, 2019.
  1. matt e
    i needed new inserts for a pair of hubs im refurbing so got a few made up, they come with a pair of grease bolts and also i got them made up with a few channels on top so the grease can get down to the needle bearings.
    £105 delivered the pair
    48711729738_31bf991fe9_c.jpg Lower insert by matt eaton, on Flickr
    GL08RBB likes this.
  2. matt e
    3 left
  3. Sorry for being new. But where is it going and what is it for?
  4. matt e
    on the MK2 (225,R26,DCI175) they use a needle cup bearing on the hub at the front and the bearing breaks down and can wear the insert which the bearing sits on. these replace the worn insert and can supply grease to the bearing making it last longer
  5. Thank you. now I understand
    matt e likes this.
  6. matt e
    2 pairs left now
  7. matt e
    got a another batch made up now
  8. Hello Matt! Alex here, from Romania. I'm new on the forum, just made this account so I can ask you if the inserts are still for sale. I would like to get hold of a pair of them. I like the grease-bolt and channels idea. I have a couple of friends in the UK that could pick them up and send them over to me, but I would be needing some sort of contact data so that they can get in touch with you. Thanks!
  9. hi mate, what specific material do you make the insert please?
  10. matt e
    dont do them any more sorry
  11. ok thanks anyway
