MK2 battery relocation kit
Discussion in 'Car Parts For Sale' started by matt e, Apr 28, 2019.
  1. matt e
    would there be any interest in a battery relocation kit for the MK2?
    it would come with everything needed to move the battery from under the bonnet to the spare wheel well. all the cable would come precut to length and have the connectors pre clamped and all the fixings. it would also include a new metal powder coated ECU mount which has the option to run a oil catch can, if that option is chose i can supply the catch can and fittings for it. relocating the battery in the boot allows you to easily run the air filter to under the headlight for cooler air.
    kit includes
    powder coated ECU bracket
    25mm2 power cable
    25mm2 earth cable
    fuse holder holder for engine bay fuses
    battery box (fixings to hold to boot floor included)
    fixings for new ECU bracket
    oil catch can kit £245 (catch can and fixings included)
    without oil catch can £220
  2. Hi Matt
    I'd be interested in the full kit.
    Is the catch can easy to plumb in and how are the battery cables routed to the rear?
    Richard
  3. Top bit of kit that is easy to fit as Matt has done all the hard work. A dremel helps with removing the paint from the chassis for the earths and a coat hanger to get the battery cable through the bulkhead grommet helps. Recommended.
  4. Thanks for the info Chappers.
    Put me down for one Matt.
    matt e likes this.
