Mk 2 front bumper under tray.
Discussion in 'Wanted' started by Nath84, Jan 7, 2015.
  1. as title mine has gone missing.
  2. I could do with one too as mine had to be brutally removed to replace the cat as the bolts were just spinning! They're about £130 from renault iirc?
  3. Mines not present either. Same as normal megs or different?
  4. I fitted a standard mk2 meggy one to mine. Fitted over the support brace paid 1
    £10 as the scrappies.
  5. Theres one for sale on the other site for £20
  6. Can't look on there as I'm not a paid member and is the standard one a straight fit or does it need to be modified.
  7. It'll be more than likely a straight fit. As the subframes that they bolt to are standard across the range
  8. What about the bumper are they the same shape?
  9. Mine was a direct fit of a mk2 P1 standard 1.6 I think. 3 bolts up front 3 at the rear.
  10. Do you have a p1 or p2
