225 missfire please help
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by cmas, Nov 30, 2019.
  1. Hello friends I wanted to consult you about the problem in my car. My car 6900 rpm cutter should enter 6000-6500 missfire sounds like throws and 5. when you press in gear, like the 5800, the instantaneous pressure stops and comes back rarely. To solve the annoyance of my car,injectors, coil,spark plug,cents setting,crank sensor, throttle,oxygen sensor and fuel pump I checked, none of them changed the problem yet none of my software tool new Turbo is original. Please could you help.
    we are looking at all the data with the original fault detection device, all normal and there is no fault.
    My car 2005 model 2.0 turbo 225 hp
