Megane vacuum pipe help...please :)
Discussion in 'Megane Discussion' started by DavidSF1, Aug 8, 2014.
  1. Hi,
    I recently fitted a dump valve to my megane but unfortunately damaged a vacuum valve in the process. Iv had a search and found a thread where someone had the same problem but it didn't say where exactly to get a replacement one from. The damaged part is circled in the picture below.
    Would the eBay link below be suitable to use on my Megane even though it's a VAG part?
    http://m.ebay.co.uk/itm/171396464705
    Also what does the pipe/vacuum valve actually do? Would I be able to replace the pipe with some of my left over forge vacuum pipe that I got with my dump valve? The current pipe feels quite solid unlike the dump valve piping so I wasn't sure if it would be ok to use. I assume as long as the internal diameter is the same it should be ok?
    Thanks in advance for any help!
    David.
  2. Yep just use vac hose I can't remeber for that if it was the 4m or 6 I used on myn
  3. VW and audi share that valve witj the megane
