Megane Trophy 4 makes chirping sound
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by la_st, Jun 27, 2020.
  1. I own Megan Trophy RS 2019.
    After 2000km , when the car is worm it started to make a squeaking/chirping sound when I press gas pedal. Car is at mechanics for a month now, nobody has idea what is wrong. Any idea? Thank you
  2. Sounds like something rubbing maybe on the disk, have you jacked it up and tried spinning the wheel to see if it will still do it or rocked the suspension around with the car stationary at all?
  3. its brake pad, guessing goes away if gently apply brakes maybe
