Hi guys, i have searched for threads but couldn't find anything so thought id ask the question. Is there anywhere i can get any spacers smaller than the 20mm option for a megane rs250, as thats a bit excessive for myself?
I remember searching a year ago but I'm afraid I couldn't get anything. The problem is that the protrusion from the discs prevents you from putting spacers on that are any smaller, really. I did measure it and bought some 16mm spacers but they had a chamfer on the bore which causes a step in to the 16mm and so they wouldn't sit flat. I think this was on the rear, but the front is probably the same. I ended up fitting 20mm rear bolt on spacers and 10 front universal spacers and then doing a stud conversation at the front. I hope this helps
