Megane RS250 gearbox cable help
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by linusviklund, May 29, 2022.
  1. Hi!
    Is there anyone who might be able to help me locate a partnumber or such for the plastic piece holding the two gearbox cables?
    Ive put a cae shifter gearbox bracket picture for reference.
    Im looking for the plastic piece wich you drill two holes into according to the picture.
  3. Someone has drilled them holes on the bracket for some reason, no need to do this on a new one
    Sent from my CPH2025 using Tapatalk
  4. I see, thank you.
    Mine is broken thats why i need a new one.
    So this partnumber would be the plastic bit thats mounted on the gearbox correct?
  5. Yes it is, I had to buy a new one as I broke mine taking the gearbox out one time
