Megane RS MK3 - Powerflex Upper Right Mount Insert
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by yangtastic, Apr 22, 2019.
  1. Hi guys!
    Thinking of purchasing either PFF60-720 / PFF60-720BLK.
    Yellow vs Black. What do you guys recommend?
    In regards to installation, easy DIY? Fairly straight forward or is it a bit finicky?
    Thanks you!
  2. Feirny
    Feirny RSM Admin
    I'd go yellow, black gives massive cabin vibration and yellow is enough.
  3. Easy to fit - just put a jack under the engine, lift it so the weight is off the engine mount. Remove engine mount, fit the insert and then fit the mount back.
  4. Yellow for road/DD use
