Megane RS/Cup differences
Discussion in 'New to the Club? Why not introduce yourself?' started by Shaun Anteney, May 13, 2017.
  1. hiya - looking at buying a Megane RS. Bit confused on what spec.
    What is the difference between the Cup and the RS with a Cup Chassis?
    Am I right in thinking you only get the limited slip dif in the Cup and not the RS with Cup chassis?
    Am I right in thinking the model changed in 2014? what are the differences or is it just cosmetic e.g updated sat nav unit? Is the original one on the older models any good? looks a bit basic compared to the newer one!
    Thanks!!
  2. Cup or Cup chassis = diff
  3. 100's of threads on here with similar questions, spend a bit of time reading them
  4. Cup or cup chassis cars;
    LSD
    Different Gearbox ratios
    Different springs
    Bigger anti roll bars
    Red calipers
    Prob some other bits I can't remember right now
  5. I believe the new model (last edition) cup comes standard with chassis and LSD, whilst the older versions it is an optional extra. So 265 optional, 275 standard
  6. Different ratios? I don't think that's right.
  7. Same gear ratios.
  8. Space Cadet likes this.
  9. That's different no? I'm not a tech mind!
  10. Ah ok that explains the mph difference then I assume
  11. They are on that Renault press page I'm pretty sure from memory that's just the first one that came up on google and I can't be assed to look for the others!
