Megane RS 265 cup white Nacre ph3
Discussion in 'Megane Projects' started by Daviej, Apr 3, 2018.
  1. Thx mate!
  2. Taken by Apex
    Taken by Tourifotos
    manugtt, StephRS, Jonny157 and 2 others like this.
  3. Soon I’m about to order this @ GT Performance, for the moment they are on holiday
    GT Performance titanium exhaust system
    6,5kg Total weight
  4. Update nr ..
    4 point harness Schroth Racing :smile: wide version in red off course :tongueout:
    Mikeyjp likes this.
  5. Yes! Yes! When are we gonna do some driving man :-D
    Daviej likes this.
  6. I don’t know mate , I hope soon!
  7. De Schroth Racing 4pt harnass are mounted
  8. Yesterday StephRS came allong to vistit me and picked Up his trophy R rear seat delete cover from Renault [emoji41]
    He took Some pictures, and this is one of them [emoji41]
    StephRS likes this.
  9. Siemens Deka 630cc injectors are in da house [emoji41]
    Mikeyjp likes this.
  10. Are model is your schroth harness, the clubman II version
  11. Schroth Racing Profi II ASM FE in red :-)
  12. Thanks, what were the connection ends like. Were they clipped onto fixings or bolted
  13. Directly bolted :-) otherwise You have a lot of noise :-)
  14. That's starting to make sense. So the brackets on the ends you bent to shape then bolted them in
  15. New frontlip and skirt blades are mounted, also the Carbon CAE shifter cover
    manugtt, Pyper, VW TT and 1 other person like this.
  18. Just ordered the GT Performance Titanium exhaust line and the HKS blow off valve for the new turbo
  19. Yesterday my GT Performance titanium exhaust Finaly arrived!! Stupid DPD transport!
    This night i’ve mounted the exhaust, the HKS blow off valve is for the new hybrid turbo
  20. The red Braid Winrace A wheels left the nest, and been replaced by
    OZ Racing Allegeritta HLT 18” 8J ET43 with Nankang NS2R semi slicks on them ( 235/40/18 95Y )
    Pyper, VW TT and Si271 like this.
  21. Lightweight crankshaft pulley delivered from Zagreb 8)
    Mikeyjp likes this.
  22. This car is stunning [emoji108] those new wheels will look great too
    Daviej likes this.
  23. How do you rate the quality of the exhaust. Does it seem well made.
    Daviej likes this.
  24. Thx! I hope! They are allready under the car :smile: much smaller than my Motec Nitro in 9J wide
  25. Tho...
    It’s well made , Good Quality !
    But I Need to drive 1500-2000km , than the wool is completely burned out and gives the right sound. I only drove 70km since i’ve mounted it
  26. New tension roller and belt are arrived today at the local dealer. Tomorrow morning fitting time !
    This morning I removed the old belt, belt tensioner and old pulley. And allready placed the new lightweight pulley!
  27. Pictures of the new lightweight pulley , with new tension roller and accessoire belt.
    Also put a small grill inside the left wheelarch, to circulatevair over the itg cai :smile:
    Pyper likes this.
  28. This morning I had Some time to shoot drive her and shoot Some new pictures with the OZ Racing Alleggerita HLT wheels :smile:
  29. Looks amazing as always. Which front splitter is that?
    Daviej likes this.
  30. Thx! Custom made in composite :-)
  31. I'm loving that grill idea for the ITG!
    Daviej likes this.
  32. Better pictures :smile:
    Jonny157 and VW TT like this.
  33. New OZ logo’s in carbon
    Pyper and trickmansa like this.
  34. Net akkoord gegeven voor nr 2
    Set omvat
    Nieuwe Renault Megane RS boite
    Licht vliegwiel
    Twin Disc Clutch
    Drexler sperdiff
    Nieuwe drukgroep, of hoe noemt het ..
    TsArno likes this.
  35. New gearbox in place with
    - new slave cilinder
    - new pressure bearing
    - lightweight flywheel
    - twin disc clutch
    - drexler limited slip diff 50/40
    The clutch and flywheel is a kit from CGR :wink:
    Now I have to place the ‘clutch catch adjuster’ to change where the clutch catches on the clutch pedal :smile:
  36. Now I’ve started with Some other things Before i disconnect batttery, remove Battery box and engine ecu.
    Carbon door panels and rear panels, full custom job! Arrives with knly the hole to open the door. The rest You have to make yourself :smile:
    Oscar Henche Juanico likes this.
  37. Hi where are these from? Cheers
  38. Ordered at a shop of a friend of mine :smile:
  39. l
    Link please mate
