Megane R26 Ultra Blue 2008 - 50k Miles - £8995 - Extensive Recent Work/History - Huge Spec
Discussion in 'Cars For Sale' started by Matt9566, Sep 25, 2022.
  1. Thought I would see if there’s any interest on here before I put it up for sale properly on eBay.
    ** For Sale **
    Renault Megane R26 – Ultra Blue – Build Number 3296
    Current mileage ~ Low Miles 50,750 (garaged so shouldn’t rise)
    HPI Clear & No Outstanding Finance - 2 Keys
    The car is in fantastic condition for its age with just a few age-related marks here and there, this is definitely one of the better ones and has clearly been very well looked after by each of its owners. It has always had high praise from any garage that has worked on it.
    The interior is in excellent condition with no wear to the Recaro front seats whatsoever, the rear seats are brand new leather ones from the Lux model that someone had in storage, some very subtle carbon dipped parts & the apple car play screen make the interior feel a lot more modern (see full list below) **I will upload interior photos when I am home**
    The car has Full-Service History with the most recent service/major work as follows;
    In June 2022 the car went to RickyP RPM (my go to trusted Renault Sport Specialist) for the following;
    - New R26.R Clutch including LUK Metal Slave
    - TTV Single Mass Flywheel
    - New OEM Flywheel Bolts
    - Motul RBF 660 Fluid
    - Redline MTL 75W80 Gearbox Oil
    - Genuine Cambelt kit, Auxiliary Belt Kit and Water Pump, Cylinder Plugs, Cam Seal Kit & Type D Coolant
    - Engine Oil & Filter change - Millers Nano Drive CFS NT+ 5W40
    Alloys refurbished in Gloss Black about 25 miles ago
    All invoices and receipts present for all work carried out.
    Modifications/Recent Maintenance.
    Engine
    · Full Cambelt Kit, Aux Belt Kit and Water Pump, Cylinder Plugs, Cam Seal Kit & Type D Coolant @ 49,508 (June 2022)
    · RS Tuning Remap – 296bhp/303ftlb (printout present)
    · R26.R Clutch, LUK Metal Slave & TTV Single Mass Flywheel @ 49,508 (June 2022)
    · Miltek Exhaust
    · RS Tuning 3 Inch Decat
    · Pro Alloy Intercooler
    · Forge Hard pipe Kit
    · Forge Induction Hose
    · Siemens 630cc Injectors
    · Forge Recirculation Valve – Yellow Spring
    · Forge Sensor Brackets
    · Ramair Filter
    · Phil Watkins Short Shifter
    All of the below replaced less than 10k miles ago at around 41k Miles;
    · New Febi Engine Mount – Powerflex Insert
    · New Febi Gearbox Mount – Powerflex Insert
    · New Febi Upper Torque Mount
    · New Vibra-techniks Lower Gearbox Mount
    · New 4 Bosch Coils
    · New Genuine N75 Valve
    · New Genuine Fuel Pump
    · New Genuine Air Temp Sensor
    · New Genuine Thermostat
    · New Genuine Crankshaft Sensor
    · New Genuine Coolant Temp Sensor
    · New Genuine Spark Plugs – Gapped to 0.7
    · New Genuine Sump Gasket
    · New Genuine Metal Dipstick
    Suspension – As above refreshed around 41k miles
    · New Genuine Front and Rear Shocks
    · New Genuine Top Mounts
    · New Genuine Bottom Arms
    · New Genuine Drop Links
    · New Genuine Anti-Rotation Links
    · New Cooksport Springs
    · New Genuine Track Rods
    · New Genuine Inner Tie Rods
    Brakes – Refreshed @ approx. 48k miles
    · Godspeed J Hook Discs Front and Rear
    · Performance Friction Z Rated Front Pads
    · Ferodo DS2500 Rear Pads
    · Motul RBF660 Brake Fluid
    · HEL Braided Brake Lines
    · Calipers Refurbished (few small marks now)
    · Pure Motorsport Stud & Nut Conversion
    Interior
    · Snappy Alcantara Steering Wheel with stitched R26 logo
    · Genuine Renault Sport Gearknob
    · Genuine Leather Gaiter
    · New Leather Rear Seats and Armrest from Lux Version (Trimmed in Alcantara)
    · Carbon Dipped Centre Console, Door Handles and Gear Stick Surround
    · Pioneer SPH-DA230DAB Double Din with Apple Car Play and Steering controls adapter
    · Turbosmart Gauge Cup
    · Turbosmart Boost Gauge
    Exterior
    · New Genuine Decals Front and Rear
    · New R26R Headlights
    · New R26R Spoiler
    · New R26R Fog Light and Headlight Washer Blanks
    · Wheels Refurbished in Gloss Black (August 2022)
    · Michelin Pilot Sport 4S – in the correct 235/40/18 size - Fitted @ approx. 48k miles, loads of tread left
    Things to note
    As with all cars (I want to be as honest as possible) there a couple of things to point out:
    · EML Light is on sometimes due to the Single Mass Flywheel, you can have a map tweak to sort this out I just haven't got around to it and it hasn't bothered me to be honest.
    · There is a bit of lacquer peel on the drivers door which I have tried to picture - one small bit just under the window plastic near the wing mirror, a small bit further down and some at the bottom near the sill - I have been quoted £350 to sort this (from a proper bodyshop) but I just don't feel it needs doing as you don't really notice it – See photos
    · Would benefit from a new rubber front splitter, all clips intact and fitted properly, just a few marks from speed bumps, they are about £65 from Renault I just haven't got around to ordering one as I don't notice it much.
    Summary
    There is a folder full of parts receipts with the car backing up the front end/suspension refresh, engine parts etc and all of the recent work carried out, along with photos of the work in progress. Please see photos
    The car is mechanically perfect and I don’t think you will find one at this mileage, that drives this well, having had almost everything replaced in the last few thousand miles. These cars are getting older now and the full refresh has definitely tightened the car up to just how it was from factory – if not better!
    Genuine reason for the sale, I have 2 cars, a daily and the R26, I’m just going to sell both and have one car which will suit my current lifestyle better. Will be sad to see the car go; they really don’t make them like this anymore.
    Price - £8995.00 FIRM – Bank Transfer Only
    Location – Barnsley, South Yorkshire.
    I am not interested in any offers or swaps, any received will be politely ignored. I am in no rush at all to sell the car, it is currently clean and in my garage, I am happy for it to stay there if the right buyer doesn’t come along.
    Any genuine buyers I am more than happy to answer any questions that you might have, provide more photos, collect you from the local train station.
    ** Please note - I am away until Monday night, but any viewings can commence from Tuesday afternoon **
  2. Lovely looking and great spec glws
    Matt9566 likes this.
  3. What a perfect example of a well maintained car. That list is impressive and hope she goes to a good home. Wish we had private sale options like these here in South Africa. The Megs here are sadly butchered before resale.
    GLWS bud!!
