As title says, bare centre console removed from my 225 F1, same as the R26 without the button for AC as it has the climate control panel. This is ideal for someone to carbon, paint, wrap, or trim! All clips and lugs in tact, slight bit snapped off right at the bottom lip which slots in by the OBD reader, this will no way affect the fitting quality of it. £20 posted! Cheers, Jon
Forgot to mention, this was cut to fit my double din, so if you have one or planning on getting double din, ive saved you the job, this should still fit standard stereo and cubby hole
