Hello Would like to get some sprayed the same color as the car. How hard is it to change these over? as they have the keyless entry ect If its easy enough to do, let me know what you have thanks
Pretty easy tbf, theres a grommet in the side of the door, remove that, and theres a mechanism with a ledge that you need to hook and pull (takes abit of faffin gettin the right angle to pull) then the lock part/cap pulls out, then the rest of the handle pulls towards the bit youve just pulled out, and comes out, but like i found out the plug for the hands free sensor in the handle wont come out, so i had to unscrew the handle in place and fit the new sprayed handle to the existing sensor. I happen to have a spare set of handles, the one side having the bit from the inside with the securing mechanism, so you can see how it works. Where you from?
Hi, I live near Stratford on Avon, does not sound too bad of a job, I did my clio ones as they had gone pink lol
Sun eve after 6pm any good? work late shifts Fri and Sat, unless you want to drop them in where i work
I can do either mate, i will pm you my number. Oh, by the way the passenger handle does have a tiny chip in it, can easily be rubbed down/filled with primer. Just thought id let you before i forget.
