Hi I've got a megane f1 team looking at a suspension refresh are the top mounts the same as a standard megane thanks
Yeah exactly the same across all the meg 2's, 1.4, dci the lot What are you wanting them for? Only reason I ask is because the RS models don't really use the top mount bearing, the swivel bearing does all the work. I bought a set brand new for £135 only to find out at Mark's that they do F all! The rubber might wear a bit, that's it.
O right thanks for that I was going to do a suspension refresh and just wanted to have the front legs up bolted up so it was a straight swap over without splitting old shocks
