Megane 3 RS Brembos
Discussion in 'Car Parts For Sale' started by Daan2D, Dec 13, 2015.
  1. For sale.
    M3RS front brembo calipers L+R
    Calipers are in good working condition.
    Seals are good and the bleed nipples turn.
    Calipers come with pad fitting pins and brakelines
    Pics:
    Price: £260 posted
  2. ianplymouth
    Hi daan
    PM sent
  3. Ian u have a pm back
  4. What about me
  5. ianplymouth
    Get your bloody own :wink:
    I am saving bits up for when i collect my .r from you
  6. These won't fit a 225 without the 250 discs or big brake discs suited for these calipers. 330mm discs won't work either as the bell is too large.
  7. This is correct will work with these though
  10. ianplymouth
    i will make them fit, i have a welder :wink:
    Was looking at 6 pot Porsche callipers, just to be different :rolleyes:
  11. ianplymouth
    got me thinking now Steve
  12. They work with 330 and even 356 discs, Meg3rs discs suits to but they need a redril then. Tutuur back to school and do your homework mate:wink:
  13. You'd rather go back to school Daniël. I have 250 calipers and 330mm discs at home, they don't fit because the bell is too large :wink:
  14. ianplymouth
    Okay then, where can i get these 356mm disc from please, pretty please :wink:
  15. Reyland will help you out
  16. ianplymouth
    Thank you very much sir :cool:
  17. Then u have bells that are to big. pics in threat speak for them self. As they fit on 356mm discs they do it also on 330mm cause they have the same bells. You get a Minus degree for your lazy homework :wink:
  18. 356mm discs grooved and drilled
    356mm discs in 17inch cup speedlines with 225 brembos cause 250 brembos are to big for the wheel.
    redrilled 250 discs
    Thats it for now!
    Ian thanks for the purchase!
  19. ianplymouth
    I've got 18" wheels so i would be okay then ?????????????
  20. Not sure, the 225 calipers in the wheel are clio R3 rally spec calipers. They are modified to suit 17inch wheels.
  21. ianplymouth
    gotta be worth a go, if not i'll fit standard 250/265 disc's,
  22. fine by me, i must be crazy then... Have you fitted them to 330mm discs?
  23. Send them off today Ian, cant sent pm atm cause your inbox is full.
  24. ianplymouth
    Cheers Daan
    I have empty my inbox
  25. ianplymouth
    Hi Daan
    I had a big heavy box delivered today
    Ian
