Hi, could do with a bit of help choosing a replacement battery for my 275 trophy. Does it reduce the options with it being stop/start ?. Size and minimum Ah/A would be great. Thanks in advance.
OEM part is: 244106154R. L3 EFB 70Ah 720CCA. Size in mm is 278Lx175Wx190H. Can be replaced with a 096EFB or 096AGM battery (AGM is better). This is what I got as a replacement: https://www.tayna.co.uk/car-batteries/exide/ek700/
Conveniently the dash asks if you have fitted a new battery when the battery is first connected. None of the coding needed unlike on some other modern stop/start cars.
