Hi Guys. What is the correct part number for Brembo pads for a Megane 3 RS 250 CUP please. Are they made by Ferodo or is that just another grade type you can use. I am getting some confusing info. Just bought a set for mine but although listed on box for mine they are different shape. The new pads are curvy and pin holes towards middle. If I use OE renno are they Brembo or Ferodo ? The ones I bought are Part number P 68 036 [For Clio 111 RS 06- MEGANE 11 RS 04 - MEGANE 111 RS 08 -] I am guessing then NON cup!! If I use BREMBO pads are they same as Renno's Cheers Andy
so the original fron brake pads for 250 CUP are from ferodo. see on the picture the bottom one. I do recommend to go for an upgrade. If the once u bought are made for Clio and MRS II, they will not fit as the brakes on MRS III are differnt
Thanks Sebinko. So Ferodo are OE then? The new ones I have DO say MRS III too from 2008 on. So just wrong then. Unless they are for non cup. Cheers Andy
The new ones you have there look like the right pads ie for MRS III not sure if the cup and non cup pads vary but I doubt it. They definitely aren't for the clio, they are different
