Megane 275 exhaust
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Tom, May 18, 2016.
  1. Tom
    Tom
    Afternoon All,
    I hope someone can help.
    I have recently taken delivery of my 275 Cup S with a standard exhaust. I would like to make the car sound a little louder and free up some more pops and bangs....
    what are the most popular ways of doing this? Aftermarket systems? Decat on standard car?
    any help is appreciated!
    thanks
    T
  2. Midbox chop is probably one of the most common mods outside of having a catback system
    Bowen likes this.
  3. Tom
    Tom
    thanks - although I would rather not "chop" the standard exhaust. has anyone fitted a decat to the standard exhaust? if so does this make a difference to the sound?
    thanks,
  4. Well tbf, if you go after market cat back, youve got to cut the exhaust to get it off, and the majority of the after market cat backs dont have a mid box anyway, and a decat takes hours to fit.
    Bowen likes this.
  5. And a mid box chop is removing the centre box and replacing with a straight pipe.
  6. Mid box chop is easiest and cheapest by far. Have not regretted it
    Sent from my Nexus 5 using Tapatalk
  7. Another for midbox chop. I also have a decat and like the way the system sounds.
  8. cgrautomotive
    cgrautomotive RSM Trader
  9. I didn't really notice any noise difference with a midbox chop just a few more pops. Decat is the way forward for overall pops bangs and noise. When the exhaust is hot the bangs are crazy!!
  10. Tom
    Tom
    If I went for the "mid box chop" how easy would it be to put the silencer back in?
    T
  11. Also interested in this^
  12. Tom
    Tom
    Has anyone been able to put the middle silencer back in after removing it?
  13. It would all depend on how they do the chop. If its clamped both sides then all you need to do to refit is to get some sleeves to sleeve the box section back in place. On mine thou, they only clamped the front part, the back was welded to reduce the chance of it leaking as the joint would be against the flow of the exhaust.
