drivers window is stuck down 2 inch. Won't operate the drivers window or passenger side. Checked passenger side switch but that makes the passenger go up and down. Checked the 30a fuse in the glovebox but seems fine. Anyone have any ideas. Thanks
Can you adjust the wing mirrors? If not then I would say it's the window switch unit that needs replacing. Had to do it myself when the window switches broke.
I couldn't adjust the mirrors either. I pulled the fuses in the glove box then re tried it and it went back up. I think your right it's the main door switch. How much was a new one
