Megane 265 Lux forged (rebuild)
Discussion in 'Megane Projects' started by ianplymouth, Dec 4, 2023.
Tags:
  1. Standard at the moment, was thinking in the long term of, turbo adapter and Downpipe to suit, with a set of rods, but I’m led to believe that finding a rod to fit oe pistons is a bit of a pain
  2. Standard at the moment, was thinking in the long term of, turbo adapter and Downpipe to suit, with a set of rods, but I’m led to believe that finding a rod to fit oe pistons is a bit of a pain
  3. ianplymouth
    If your going to strip it to put rods in then in reality it's best to do the job properly, i am sorting one out atm, i have a set of Catcam rods waiting to go into mine, i will see if they will fit standard pistons at the weekend.
    You must also consider fitting different valves, the standard ones are a serious weak point as well.
    I have an adapter that i bought from the USA, i'm going down a slightly different route with mine, so not required for mine any more.
  4. Your adapter is for a t4 flange is it not
  5. ianplymouth
    T4 twin scroll
    Why what turbo are you thinking of wanting ????
  6. Something that would work well at 380hp for track
