Megane 265. Bleeding after thermostat change
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Danny Danger, Mar 24, 2018.
  1. changed the thermostat today, lost a bit of coolant but the reading in the tank was between min and max. Turned car on and left the top off the coolant tank.Ran it up to temperature , the coolant inside the tank started rising above the maximum level so I've turned it off and it started to settle again.
    Is this the right way to get air out
