R26 Megane 250 turbo on R26...
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Goodwood automotive, Mar 5, 2017.
  1. Can anyone confirm if the intake hose from a megane 225/230/r26 can be the same diameter to fit on a 250 turbo. Or is a larger pipe diameter needed??
  2. ianplymouth
    If its the air filter intake pipe, then yes in fact all the hoses will fit apart from the hose to the intake manifold, but the 250 throttle body won't work anyway, so you will have to use the 225/r26 throttle body.
  3. Thanks Ianplymouth! Yes I was asking about the air filter intake pipe. Cheers dude!
  4. ianplymouth
    You fitting a 250 turbo then ?????
  5. Indeed I am dude. Amongst a hell of a lot of other things. Will be posting a lot this month. (Ring trip in April..)
  6. ianplymouth
