Megane 250 turbo on a 225 ?
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by geegreen, Nov 26, 2015.
  1. Hi chaps is this something simple to do or will I need to adapt this turbo to fit ? Also will it handle more power then a standard 225 turbo ? Look to use this rather then a hybrid turbo ...
  2. Straight swap.
    Produces more power
    Map to make the most of out if.
  3. How much are you selling them for Andy?
  4. I have 2 options.
    £320 and £420.
    £420
    new CHRA new comp covers with Actuator but no hot side. Use your current turbo hot side
    £320
    new td04l15t chra ( core ) with used comp covers , no actuator or recir
  5. Very good price very tempting
  6. Christ, basically new 250 turbo for £320..:eek:
  7. would need 630cc's to actually make use of the power though
  8. Realistically you'll need 630cc injectors, decat, intercooler and 3" exhaust to make the most of it.
    I was going to go for one but Paul at RS Tuning said really a 3" exhaust would be needed to make the gains it can.
  9. Beeftec is right, i assumed he already had this on
  10. FYI there is a fb group discount £175 for those 630cc injectors :-)
  11. Yeah I have 630cc forge front mount and the K tec 3" decat and straight through exhaust system so should be ideal .
  12. If you are on standard internals then Paul @RSTuning will limit the torque to 300, and the 250 turbo is a straight swap :smile:
  13. What sort of power can be achieved with the said mods and a 250 turbo?
