Megane 250 short shift
Discussion in 'eBay Items, Pistonheads & Autotrader Ads' started by Jamie230, Oct 27, 2018.
  1. Seen an m tech short shift on ebay for £60. Seller also has a couple of megane 250 gearstick knobs
  2. Can’t find it. Linky?
  3. Is this cheap? Keep thinking I fancy a short shifter
  4. You can make your own for about £3 and 30 minutes of your time
    Jamie230 likes this.
  5. Fancy doing a group buy?
  6. I can do a "how too" later if you want :laughing:
    BIG E likes this.
  7. Doing the short shift mod on a mk3 gearbox is almost the same as the 225 one, its the R26 one that the problem, as that has to be milled out.
  8. Mark a point 25mm from the original ball stud
    drill a hole
    I tapped mine and put a nut underneath to lock it off, not sure you need it , belt and braces tho, i think on the 250/265 you have to move or cut a bolt that is in the way.
    Not done mine yet, sort of happy with it, will be a winter job
    FatRS likes this.
