Megane 250 coilovers.
Discussion in 'Wanted' started by dale.groves, Nov 9, 2016.
  1. As in the title, the higher end is what I'm after, Kw clubsports, v3, ast etc. Ideally adjustable top mounts, but most certainly adjustable damping. Not too worried about age, condition needs to be good though.
    Sent from my HTC One_M8 using Tapatalk
  2. Can you translate the description please dude? Are they in Germany?
  3. -Jamie-
    What do you want to know? 3000kms and not used in winter
  4. I'm looking at the ohlins, and am I right in presuming that they run oe cup springs!? Cause they sure look like it. And they certainly don't look like ohlins springs on their aftermarket equipment.
    If so, that's steep for single adjustment shock absorbers...... regardless of brand.
  5. Öhlins are using Cup springs unless you dont take them with Trophy-R composite front springs.
  6. So in that case the rear isn't even height adjustable. And I bet the front is almost maxed out (near bottom and of adjustment range) due to the spring length.) When in a proper setting. No top mounts either.... I have no interest in ohlins. Unless it's their "proper" road and track, which looks completely different.
