Megane 225 replacing everything please HELP!!!
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by richmeg, Apr 28, 2017.
  1. Guys,
    Ok next weekend I am replacing my wheels, suspension and brake set-up (inc. calipers) for better condition parts off newer model Megane's.
    I am just wondering if you could give me any advice at all (since I'm replacing myself) anything I might need in terms of special tools or grease/lube??
    Or if there are any other smaller components that maybe worth changing in the process while the bits are off the car. So far I have replaced the following steering/suspension parts;
    Suspension Top Mounts
    Steering Rack
    Steering Arms/Track Rods
    Steernig Track Rod Ends
    Anti Roll Bar Links
    I was thinking maybe to get a set of Mr Pinks Brembo Pins for the calipers . . . would it be worth fitting these to the rear as well / or they only fit the front Brembo's?
    See I'm gonna need all the help I can get!
    Cheers,
    Rich
  2. matt e
    pins are only needed on the front
    wishbone bushes (poly bushes)
    balljoints
    wheel bearings
    hub bearings
  3. caymanr26
    caymanr26 Events Liason
  4. Get some of the hub bearing grease bolts off @matt e and grease up your bearings for an easy bit of preventative maintenance
    matt e likes this.
  5. Cool thanks soo much for your help guys . . .
    So I know about the wishbone bushes and ball joints as I've looked into this before.
    Just to clarify the wheel bearings are attached to the disc at the back so we're only talking front wheel bearings and front swivel hub bearings?
  6. matt e
    yeah the front
