Megane 225 Engine Undertray/Splash Cover
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by ZaakRS, Jun 8, 2016.
  1. Hi guys,
    I'm in need of a new engine undertray and was wondering if you need anything special for a 225, or if a standard Megane one will do the trick.
    I've seen this on eBay: 121179395664
    I'm fairly sure they use the same tray but just wanted to double check.
  2. matt e
    Apparently the ones from the lower spec meganes do fit
  3. Yes the lower spec Meganes do fit they just a bit longer than a sport one
  4. Cheers guys
