Megane 225 engine rebuild manual
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Ljacobs, Oct 27, 2019.
  1. Hi All,
    I'm currently rebuilding a 225 turbo engine from the bottom up, engine code F4R 774. I have looked high and low for an engine rebuild manual but I have found nothing at all. I'm really looking for torque specifications, bearing clearances, and any special procedures.
    Does anyone have anything that I can use? Even if it's for a different spec of F4R engine considering they are quite similar.
    Lee
  2. ianplymouth
    I did post up the torque figures for the engine on here, but i can't find it anywhere, sorry
  3. ianplymouth
  4. ianplymouth
  5. ianplymouth
  6. ianplymouth
    The engines are virtually identical, only difference is the crankshaft bolt torque sure its 40nm and 90degrees.
  7. Hi, you don't happen to have bearing clearances, piston ring gap and cylinder bore to piston clearance technical data do you?
