My service and air bag light has decided to appear on my dash, I'm sure it's a common problem and has been talked about before?! Any help or ideas on easy fix wud be great cheers.
Under the seat connections disconnect. If you plug it into clip or rstuner it will tell you which is at fault.
Mine does it every time I move the drivers seat forwards... wiggle the cables under the seat and it goes off...
Mine did this and moved the wires on the spiral cable behind steering wheel and all went off and was good
