225 Megane 2 Mist Style Washer Jets
Discussion in 'Exterior & Bodywork' started by Nickson, Jan 23, 2014.
  1. Charlie Howard
    Mk3, people have said the 2 and 3 use the same jets.
  2. I got the same ones you linked and they are not the same, take one of yours out, they are really easy to get off, and compare them
  3. Charlie Howard
    Oh right, I won't get them then. Have you had any luck getting suitable ones?
  4. Nope :worried: looked all over the place
  5. Charlie Howard
    My next bet is a scrapyard then. There's a scrapyard down the road that has 2 Kangoo 2's in so if they both has mist jets want me to pick up a set for you?
  6. If you can find any that fit, that would be great thanks :smile:
  7. Charlie Howard
    What's your price limit as I don't know a cost yet?
  8. Would not think a scrap yard would charge more than about £5, but OK if its a bit more
    Goodwood automotive likes this.
  9. Just to update an old thread I have found these which I’m going to try
    Will see if Renault parts direct can get hold of them
  10. Charlie Howard
    Cool let us know!
  11. So from previous comments on this page, would these fit a mk2 as well then?
  12. E9C10A7F-4A6D-47BB-B73A-C7CBD572555A.jpeg 268FAF90-5EB9-4C25-9FC5-AAF7C2B4D1B7.jpeg Well they have turned up so have fitted them which is a simple task,
    And they seem to do the job, I had to adjust them but have not driven it yet
    As I need to do the cambelt and associated bits which I will hopefully do this weekend weather permitting
    But definitely better than the piss streaks so far from a static test
    Mikeyjp likes this.
  13. Get a chance to properly try these out yet? Would be all for changing the jet style to these mist style ones.
  14. Charlie Howard
    I ordered these yesterday, I'll post a before and after video for those interested
    Mikeyjp likes this.
  15. matt e
    the mk3 use the same as mk2 then?
    if they do then your better off with the vivaro/trafic then as they are easy to adjust with a flat head screwdriver
  16. Charlie Howard
    Not sure if they're the same, the Kangoo uses the same ones as the MK3 but they changed the newer ones to jet instead of mist so getting hold of them is hard. I replaced mine and it's a lot better, get a lot more coverage. It's hard to see in the video because there's still 2 streams but also a mist. Here you go -
    Jet
    Mist
  17. Charlie Howard
    Probably not worth the bother of doing it, mist works well enough
  18. but unfortunately the mist type is no longer available
  19. Or get Vauxhall vivaro ones which are a direct fit too.
  20. hmmm, time to do more web surfing then
