225 Max Oil Temp Question M2RS
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Jukidam, Feb 28, 2021.
  1. Hey
    A lot of you drive at track and I was wondering what oil temp do you get ?
    And more important at which oil temp do you let it cool down ?
    i just want to know what should be my maximum before I back up if I go to a track or make some runs on the German Autobahn
  2. After about a 15/20 minute session mines about 90/95 but I have to really give it some shit to get that temps. Sits between 85 and 90 most of the time.
    Sent from my SM-G981B using Tapatalk
  3. in metrical / Celsius degree ? That would e awesome my friend goes to 120 degree Celsius at nordschleife
  4. ianplymouth
    The highest temperature i ever saw on my 225 on track was 106 deg C, didn't have an oil cooler fitted just the standard cooler behind the oil filter.
  5. I hit just under 120C, ambient temps were around 18C.
    But that was with a bad map with stupid boost, with a better map I was around 100C on the same track, although ambient temps were only 6C.
  6. Okay thank you all for writing
    At which temp would you back up ?
    is 120degree a good maximum ?
  7. ianplymouth
    Just kept going, might back off if it hits 150 :laughing::laughing::laughing:
    Jukidam likes this.
  8. Hahahh okay as first I need to find out how the temp is even now
    my oil / water temp gauges don’t want to work
  9. ianplymouth
    My water temperature gauge has never moved while on track, goes up a bit if you have to come in due to red flag, but i always do a cool down lap when i can
  10. Good to know !
    I have an additional water and oil gauge but need to set them up correctly.
  11. ianplymouth
    I have put an oil pressure and temperature gauge in the R26, only seen 90 deg C max on the 500 miles i've done trying to run in the engine.
  12. Yes I also had as I could remember Max 90 on the streets
