Map sensor has come loose
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by phillian, Aug 7, 2013.
  1. Is there any way to tighten it back up? There is loads of fresh oil splashed around the sensor so I suspect this is a boost leak ? Thanks
    Uploaded with ImageShack.us
  2. Naith
    Cable tie
  3. I thought about doing that but is the oil splashed around the sensor because the O ring has deteriorated ? I'll try cable tie and get back to you lol
  4. Cable ties seem fine, cheers
  5. Get a bracket made up to bolt into that hole.
    Hold it down tight.
    I'll try and have a measure on mine and knock a few up in stainless at work. But I'm on hol for 1 week from sat.
  6. Daz
    ^^^ Yup!
    Done me proud since I put mine on :smile:
  7. Forge brackets
  8. There the ones. I'm going to make a few in stainless.
