Lug Bolts for Megane RS 3
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by Illisha, Jul 5, 2019.
  1. Hi Guys,
    Got a quick one. Currently have a set of stock 8:08 steevs and was looking into getting aftermarket lug nuts for my new 18 inch advan rs wheels, only to find out that the Meg 3 uses lug bolts instead? Will my stock lug bolts work with my 18 inch advan rs wheels or am I missing something here?
  2. matt e
    you can buy studs to replace the wheel bolts but your have to buy the nuts as well
  3. Should work fine. I use stock wheel bolts on my TSW Interlargo 9x18 wheels.
    Just check the hole on your Advan, assume they would be cont style like the OEM ones
  4. Awesome, too easy. Just another silly question. If my new wheels are 18x8.5 et 50 and I use a 73-66.1 hub centric ring, does that effectively mean my offset is 50-6.9, so +43.1? If so would I have any troubles with a 235/40/18 in terms of clearance?
  5. Spigot rings done impact the offset, all they do is fill the difference between the centre bore on the wheel and match it to the hub on the car so it sits true and weight is evenly dispersed.
  6. -Jamie-
    Spigots do nothing other than centre the wheel. They are not load bearing at all.
