Hey people, I have a regular RS 250 (non-Cup). I've found loads of helpful threads on here, in regards to various lowering springs, and how they sit when installed. But I also remember reading somewhere, that the Cup suspension is lower than the non-Cup - is that just down to the springs, or are the dampers also different? I just want to know if fitting say, Cooksport springs to my non-Cup dampers, will lower the car the same amount as if they were fitted to Cup-dampers? Thanks in advance!
Personally would not fit Cooksport, h and r were not has hard and crashy, you should be able to get some cup dampers 2nd hand cheap
I've got cooksports and they are spot on I'm a fussy twat too ie if they were crashy they'd be straight off. Been fitted for nearly 3 years now
Thanks for the advice and input! I ended up going the Bilstein B14 route, as my dampers are on the way out anyways.
