R26 Lower splitter hanging in the centre on clip
Discussion in 'Exterior & Bodywork' started by Losi_8_boy, Feb 7, 2014.
  1. Anyone found a way of seating the centre part of the splitter on the bumper? Mine always comes of the clip. Don't think it helps that it slightly catches my drive though.
    Thinking a little self tapper to hold it there?
  2. Aye myn did tht untill I screwed it on done it from 1 end to another as myn got ripped off on a speed hump. Hasn't budged since
  3. Mine is ok everywhere else apart from the centre bit. Might have to try tiger seal
  4. Mine is exactly the same as yours mate. Tiger seal needed I think.
  5. Myn was like that already had a screw but didn't really help then I ripped the whole thing off I front of loads of people in a car park due to a speed hump bt aye a screw and tiger seal should work
  6. Cupra r splitter time :tongueout:
  7. I made 2 tiny holes under the ridge and looped a small black cable tie around the back of the attaching point. Can hardly notice it even when you look for it.
  8. Fantastic idea... I'll use that
  9. Good work that man! That's always bugged me about the splitter finally a fix.
  10. Mine is tiger sealed on. Pretty messy job to do!
  11. Couple of stainless self tapping screws cured mine too........
  12. Same as chap above, I tried self tappers but they weren't strong enough. Took the bumper off and put several small, quality tie wraps around the vulnerable area....not budged since and you can't see them from unless your right under the car.
  13. Hi, could you post up or PM a picture of this please mate, just fitted a new one and the centre keeps coming away as it catches the drive....don't want to take the whole thing off but I may have to in the end...
  14. I used wurth instant gasket, it sets like rubber, perfect for the job no screws required.
  15. Cable ties work well, let's it flex a little!
  16. Have. Anyone got any photos with the cable ties In place rich
