Lower Ball joint Megane RS250
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by davejh, May 26, 2020.
  1. Hi all,
    Lower ball joint has gone on my Megane RS250. Garage I use regularly have quoted me just over £500 to supply and fit a new one (said it was about 4 hours labour). This was supplying the full hub rather than just the ball joint.
    I have had a search around and have found that you can just buy the ball joint rather than the full hub from KAM Racing for £80. However, the garage are not willing to fit just the ball joint. Does anyone know anywhere in the Cambridge area that would do these? I don't mind travelling if I can save a couple of hundred pounds.
    Thanks.
  2. first thing i'd do is swerve your current fitter and find good reno indi
    what about AW Motoworks on FB ? get quote from Alex or Becca
