265 Low Temp thermostats
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by D7DPJ, Aug 2, 2021.
  1. Hello All,
    As part of my general maintenance with a new car and before a track day I was looking to replace the coolant. Like many parts on the car its all original from factory so I would imagine the thermostat is also.
    I here these are normally problematic and was going to change but noticed that engine dynamics do a low temp thermostat.
    https://www.engine-dynamics.com/Performance/pid106174/cid179/Low-Temperature-Thermostat.asp
    I was thinking this might be a worthy upgrade but wanted to have peoples thoughts if its worth doing or putting in an original or aftermarket normal replacement.
    thanks
    Dan
  2. Waste of money mate, stock thermostat is fine. Temp will still get up there with lower temp stat.
  3. So renault part or aftermarket. Is the renualt part an issue?
  4. I would fit oem Renault personally.
