Low battery light
Discussion in 'Electrical & Interior - Security, ICE, Wiring Loom' started by Adam loveridge, Jun 11, 2018.
  1. Have this issue I've checked the charging voltage from the alternator to the battery and it's recieving 14.2 volts once the engine is turned on and off it resets and then comes back after about 5 mins
    Any one had any thing like this
  2. could be voltage regulator in the alternator, if the two carbon rods are low maybe giving good voltage then low and good again, would need replace regulator, lot cheaper than new alternator
  3. I'll give that a go thanks
