Locking Car with Key
Discussion in 'Megane Discussion' started by Rosssco, Feb 26, 2019.
  1. Bit of a random one - I'm away for 3 months, and worried the battery will start to die and the alarm start playing up, so planning on disabling it and disconnecting the battery, but clearly want to lock the car (not garaged).
    Is it possible to lock the car with the key only (hence no alarm)?
    Thanks,
    Ross
    Ps. - Its a Megane 3 RS
  2. Can you not use a trickle charger? Not sure how safe it would be for 3 months though
  3. Unfortunately not as its parked out side in a (private) carpark.
  4. You could add some flying leads to the battery that you can get to easily so if the battery does die you can recharge it without having to open the bonnet - though not sure how the alarm behaves as the battery discharges fully?
  5. Could you not pop the bonnet, lock the car then disconnect the battery? Then close the bonnet and when you come back open the passenger door with the little key.
    Sent from my CLT-L09 using Tapatalk
  6. Lend it to one of your mates for 3 months
