1. I have a problem with my Megane 225 trophy
    The car keeps goin in to limp and saying check injection asr fault
    I've put new plugs coils and had injectors cleaned also changed boost control valve (n75) still doing the same
    It's been mapped before I had it but has no DV just the standard recirc .
    It will only go in to limp when I'm giving it some in 3rd at 80 evey time
    Or under hard load
    The error codes I'm getting are
    df079 motorized throttle valve automatic control
    Df004 turbocharger pressure sensor circuit
    Would it be the standard dv has it got weak you think or could it be some thing else. any help is appreciated thanks in advance
  2. I think You have same problem as mine: MAP sensor near battery fault :wink:
  3. Surly it should come up with map sensor on the diagnostic?
  4. turbocharger pressure sensor circuit = Map sensor try cleaning them or swapping them to see if the fault code moves (you've got one on the plenum to swap with).
    Although i'd also look at the throttle body to see if its sticking too
  5. think I have found the problem intercooler has split so leaking boost
  6. If you find it still goes into limp mode check the vacuum pipes, I had one pop off and it did this
