Lightened flywheel fault
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by MBC, May 23, 2015.
  1. MBC
    MBC
    Hello Technological people.
    A quick question. My R26 has a lightened flywheel by KTEC facing. It flashes up with a diagnostic problem of check emissions. I did this at the Renault dealer and they said there is a flywheel error which causes the sensor to not correctly read the flywheel because of the size difference. Does anyone else have this issue and what did you do?
  2. I've been told that it needs mapping out of it does come up.
  3. MBC
    MBC
    Thanks, Renault said if I wanted to clear it properly (it comes back up once cleared) then I would need to stick the standard flywheel back in. That is a tad too costly for me but I could consider it under the warranty.
  4. Feirny
    Feirny RSM Admin
    Get it mapped out, easiest and best option by a mile.
  5. MBC
    MBC
    Thanks for that mate. I had no idea I could get that done! Saves removing most of the engine to get the standard flywheel in!
  6. Markblack@MRS
    Markblack@MRS RSM Trader
    May just need resetting
  7. Its a r26 , so will probably throw the error again.
    I would get it mapped out
  8. MBC
    MBC
    I got it reset and it threw the error out again so it will have to be mapped out.
