1. Hello everyone, Where can i get a set of white LEDs for the interior and number plate? Thanks in advance :smile:
  2. Thanks mate :smile:
  3. LED's will start to flicker like a disco after a while if you use them in the number plate :/, need to be fused I think.
  4. Mine never did in 2 years
  5. And why would they start flickering ?
    No requirement for a fuse , if anything you may need canbus LED's which is exactly the same as a normal led with a resistor added so the car thinks there is a filament bulb on the end
  6. Ash87
    Mine flicker like a disco, think its just cus they are cheapy ones though
  7. I bought those ones in the link for my 265 and they stay very slightly lit in the interior
  8. I bought the interior led set from the other site... had two left over so used them in the number plate and they started to flicker after a week?
    And Jonny mine do the same :smile:.
  9. Can't understand why though mate, I'm sure the ad says canbus error free, so surely they should go fully out ?
  10. Fingers crossed mine work lol, I had them in my R26 for a few years and they where fine :smile:
  11. I'm going to be fitting the LED's tomorrow, Are there any tips you guys who have already done it give me?.
    I'm going to replace the number plate bulbs as well, Is it easy to remove the covers?
    :smile:
  12. Take your time not to snap the plastics.
    Dont use anything metal or conductive to remove the current ones or you will short it and blow the fuse
    some wont work after putting them in, pull them out and turn them around and they should work
  13. Thanks for that mate :smile:
