Has anyone changed the front indicators to LED bulbs? What ones did you get and do you need a resistor too?
I just put silver vision bulbs in mine front and rear. Gets rid of the horrible orange and blends in with the lights.
I've already got chrome ones in there but I want to change all my lights except the main headlight and high beam to LEDs because they look nice IMO.
Ah okay thanks! I was going to do headlights too but don't really want to dazzle anyone, wish I could though because they look so much better. Has anyone bothered with rear LEDs for brake lights etc?
done all the rear, reverse made the biggest difference Cree bulbs by matt eaton, on Flickr Reverse lights by matt eaton, on Flickr
Ah so brake, reverse and running light? not sure what to call that one, all work as standard? Are they H7 bulbs? Can't say I've ever had to change any research bulbs.
Do you need resistors even with Canbus LEDs? I've put LEDs in previous cars and there's no bulb warnings provided they're Canbus LEDs. Is the Megane different in that regard?
You can change all interior, side repeaters and side lights no problems if they're canbus but the rest of the bulbs I believe require resistors. Not sure about headlights but that's illegal anyway.
Not sure about the MK2 but the MK3 has sensors for most exterior lights. I've replaced sidelights and side repeaters fine as they use the same bulbs as interior lights.
Reviving this because I actually finally got some LEDs. The indicators require a resistor but it's all one big connection so does anyone know what cables need the resistor as they're not labelled? Also, I fitted a P21/5W LED for the tail/brakes and they light up when the headlights are on but don't get brighter when you touch the brakes. Any ideas?
