R26 Leaking Intercooler Pipework
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by DarkPand0r, Jun 24, 2014.
  1. Good Evening!!
    My R26 has a small leak from a weld on the intercooler pipework going over the engine, the system is custom and is part of a kit from TX Autosport but the welding is a little shoddy and there's a small leak apparent by small amounts of oil residue around the weld after a hard drive.
    What do you recommend is the best way to get around it?
    1. Fit new piping (Forge), this presents a problem in that the standard intercooler has been replaced for a universal which has a side inlet so would require more piping to fit.
    2. Re - weld the suspect area?
    3. Fit a silicone Joint over the area to essentially plaster it shut!
    Any help appreciated guys!
  2. If it's leaking from a previous weld you could get it ground down and redone professionally without looking tacky.
  3. As above, I would have it re-welded, would probably be cheapest option too.
  4. Yea, thanks guys. Booked in Friday to have it re welded for £50 :smile:
