225 Lambada
Discussion in 'Mechanical - Engine, Gearbox, Exhaust etc' started by Filo, Oct 29, 2023.
  1. Dear friends. I need a lambada sensor. I have a couple of numbers. Is there anyone who can confirm
    C2RS/C3RS/M2RS Early - 7700107433
    C3RS/M2RS Late - 8200590431
    8200036545Megane 225 2005 euro 3
    They should both be the same ?
  2. matt e
    they have different plugs on them
    Filo likes this.
  3. matt e
  4. I know that the R26 and 250 have a different plugs on the end's of the wire, the actual sensors i'm sure are the same, they do the same job.
  5. autronix
    autronix RSM Club Member
    only euro 6 MK3 (EMS3125 ECU) has a 5 wire widebad lambda sensor.
    any other versions (EMS3110 ECU) are using 4 wire (narrow band sensor) .
    as Ian says, sensors are the same with different plugs.
  6. Thank you. I'm ordering them
