250 KW V3 Bump adjustment knob is stuck
Discussion in 'Suspension, Brakes, Wheels & Tyres section' started by ArnoRS, Mar 27, 2017.
  1. Got the KW V3 fitted on my MRS3. Wanted to adjust the bump yesterday but the adjustment knob is stuck.
    What can I do? Already tried WD40 but it didn't help.
  2. If they are used they are probably full of muck and corrosion. I'd get them rebuilt.
  3. Applies to only the right front shock.
    Is a used set, bought from a 'Renault specialist' in Holland. They also fitted the KW's and said it was completely alright. They were able (they say) to adjust this shock.
  4. When was it installed? Older generation of KW designs sometimes have stuck adjusters.
  5. It was recently installed. Bought it from them and they installed the KW's.
    These only have the click system underneath and on top I have to adjust the rebound with an allen key.
