Just looking for some advise on these from people running them or something similar... If I was to buy the kit, what else would I need to buy for the fitting? Cheers
Jamie would you need the drop links if only looking to lower 10-15mm ? Sent from my iPhone using Tapatalk
Cheers Jamie. How come these are a maybe? What would be the factors of needing them or not? I've also heard about spacers for the driveshaft?
Nope, i wouldn't of thought so. See if the stock drop link still fits LOL, Some people run shorter ones, some dont. Spacers arnt a must, Depends how low your going to go. For all they cost you may as well mind you but i think the camber that you can run on coilovers with topmounts helps anyway
So basically neither are a must? If I wanted to run say -2.5 camber and around 50mm lower than standard this would be ok with a stock set up?
